Razer DeathAdder Chroma Optical Sensor Replacement
  1. Razer DeathAdder Chroma Optical Sensor Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
    There are 2 tiny locking pins at the back you may need to spudge the connector casing a bit on each side to release these , I did.
    John bayley - crwdns2934203:0crwdne2934203:0
  9. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
    Does anyone know what the circuitry this screw holds in place does, I completely missed this tiny screw and accidently snapped the 2 soldered components off named D2 & D3… But the mouse still works fine ?? however i do not use razer synapse anymore so i dont know if its 100% working
    woolstarr - crwdns2934203:0crwdne2934203:0
    Never mind it just came to my attention there is a set of LEDs in the mouse wheel which is what that tiny board is, soo …. RIP Mouse Wheel LEDs
  12. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement, Optical Sensor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove two 5.5mm screws.
  15. Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder Chroma Optical Sensor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the optical sensor by pulling it forward and up.
crwdns2935229:05crwdne2935229:0
Nathan D. Kappler
crwdns2935283:003/27/17crwdne2935283:0
343 crwdns2915208:0crwdne2915208:0
Baylor, Team S5-G2, Williams Spring 2017 crwdns2935289:0Baylor, Team S5-G2, Williams Spring 2017crwdne2935289:0
BU-WILLIAMS-S17S5G2
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
Guest Night - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 6,606
