The Razer DeathAdder Chroma may experience critical issues related to the device’s motherboard. To resolve them, it might be necessary to fix components below the motherboard.
Turn the mouse over so the bottom is facing up.
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
Use your fingers to identify the location of the screw under the bottom label.
Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
Disconnect the ribbon connector between the motherboard and the optical sensor.
Remove the motherboard by grasping the sides and gently pulling upward.
crwdns2935229:05crwdne2935229:0
