Razer Blade Stealth NVMe M.2 Upgrade
  1. Razer Blade Stealth NVMe M.2 Upgrade, Preparing your work area: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade, Preparing your work area: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab your NVMe ssd you want to add in. Note: There is only one slot so it is recommended you clone to your new ssd before continuing
    • To do this, we recommend having a high quality kit on hand, like the ifixit one pictured
    • Have a tray to ensure you don't loose track of screws. Remember, some screws inside can be of different lengths.
    • TURN OFF THE LAPTOP and make sure you have grounded yourself. This is vital to ensure you don't damage the laptop (Or yourself)
  2. Razer Blade Stealth NVMe M.2 Upgrade, Removing bottom plate screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade, Removing bottom plate screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are only 10 screws, use the T5 bit to remove them
    • After removing the screw lift the bottom plate from the hinge, it will free easily
  3. Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate stock M.2 drive, read and take note of the yellow sticker
    • Roll sticker back (left to right) and stick it to itself so it is out of our way
    • Use PH0 driver to puncture sticker and remove SSD screw
    • Verify one last time our new SSD has the same form factor as the stock one
  4. Razer Blade Stealth NVMe M.2 Upgrade: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth NVMe M.2 Upgrade: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert M.2 into the slot at roughly a 30 degree angle in the depicted orientation, do not use force
    • Gently press SSD flat against the mother board with a single finger and thread the SSD screw
    • Boot into BIOS and verify drive presence
This is a very simple process make sure to count your screws and set them properly.
Brandon Martinez
crwdns2935283:008/15/19crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
You probably should’ve unplugged the battery too, just as a safety precaution before touching the hard drive
Jonathan Aldana - crwdns2934203:0crwdne2934203:0
There are two spots where the battery can be disabled but given that Razer only warns about turning the unit off I doubt the battery charge will be any risk. If this was an intensive repair or replacement I would consider it a little more, but for such a quick swap it might be excessive.
Brandon Martinez -
How much faster is the razer blade stealth with the samsumg nvme m2? Can you see or feel a difference? Would you suggest it?
Lorenzo Zimmermann - crwdns2934203:0crwdne2934203:0
I can’t tell the difference, loading up games or applications it’s all the same speed, but I did not do a speed test beforehand to be 100% accurate. I also run linux so there might be a slight performance gain from that. I would include better photos of the SSD for you but I moved a few months ago and it’s still somewhere in a box.
Brandon Martinez -
Were there any “pre-packaged” programs that you had trouble installing or anything special programs need to run the laptop?
Ramon Sanchez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 9,286
