Razer Blade Stealth 2017 WiFi Card Replacement
  1. Razer Blade Stealth 2017 WiFi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 WiFi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
    Do you have to remove the battery before swapping the wifi card? Is disconnecting the power not enough?
    Charles Tsai - crwdns2934203:0crwdne2934203:0
    Hi Charles,
    If you’re swapping the Wi-Fi card, you don’t need to remove the battery. Disconnecting it will suffice.
    Arthur Shi -
    Are two of these screws shorter than the other four? And if so, where do the two shorter screws go?
    James Spinella - crwdns2934203:0crwdne2934203:0
    Looks like the two shorter screws go where the trackpad is!
  5. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
    After removing the 6 screws securing the battery, mine does not come out easily. There is resistance, and I don't wanna forcefully pull it out. Is it supposed to be easy to pick up and take out or is there some sort of tape holding it down from the bottom?
    kairos - crwdns2934203:0crwdne2934203:0
  6. Razer Blade Stealth 2017 WiFi Card Replacement, WiFi Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 WiFi Card Replacement, WiFi Card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 WiFi Card Replacement, WiFi Card: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove any tape attached to the Wifi card.
    • Use a plastic spudger to disconnect the two coaxial antennae connectors and expose the WiFi card.
  7. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the single, 2 mm screw from the WiFi card.
  8. Razer Blade Stealth 2017 WiFi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the WiFi card from the motherboard by sliding it out at an angle.
Helene Willits
crwdns2935283:010/10/19crwdne2935283:0
776 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G3, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S11-G3, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S11G3
It was unnecessary for me to remove the battery. Replaced the original Killer card with a WiFi 6E Wireless Card Intel AX210 NGW Bluetooth 5.3.
James Pulido - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 3,362
