Razer Blade Stealth 2017 SSD Replacement
  1. Razer Blade Stealth 2017 SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 SSD Replacement, SSD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 SSD Replacement, SSD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to disconnect one end of the interconnect cable.
    • Remove any tape attached to the interconnect cable.
  7. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black plastic cover and interconnect cable to expose the SSD.
    • Use a Phillips #00 to remove the one, 2mm screw on the left side of the SSD.
  8. Razer Blade Stealth 2017 SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SSD from the motherboard by sliding it out at an angle.
Helene Willits
crwdns2935283:010/10/19crwdne2935283:0
779 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G3, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S11-G3, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S11G3
crwdns2942667:0crwdne2942667:0 5,344
