This guide outlines how to replace the HDMI and USB-A port module in the Razer Blade Stealth 2017. When and external device is connected to the HDMI port, if the external device is not displaying audio or visual feed, the HDMI may be broken. The HDMI and USB-A module is located on the right-hand side of the computer, and often experience issues with loose ports and external device communication. Some tools are required for this replacement.
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Remove the bottom cover of the laptop by sliding it away from the hinge.
Use your fingernail to pry up and disconnect the battery from the motherboard.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use the plastic spudger to pry out the battery.
Use a plastic spudger to lift up the press-fit interconnect cable and expose the USB-A and HDMI port module.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to squeeze the fan's white header.
Disconnect the fan connector by sliding it out toward the rear of the chassis.
Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and HDMI port module.
Use a plastic spudger to remove the USB-A and HDMI port module from the case.
