Razer Blade Stealth 2017 Fan Replacement
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to slide the fans out of the case.
Helene Willits
crwdns2935283:010/10/19crwdne2935283:0
776 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G3, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S11-G3, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S11G3
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,549
