This guide outlines how to replace the audio and USB-A port module in the Razer Blade Stealth 2017. The audio may be faint or not work. This module is found on the left-hand side of the laptop and often has issues regarding loose ports and external device communication. Some tools are required for this replacement.
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Remove the bottom cover of the laptop by sliding it away from the hinge.
Use your fingernail to pry up and disconnect the battery from the motherboard.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use the plastic spudger to pry out the battery.
Use a plastic spudger to lift up the module connector.
Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
Use a plastic spudger to remove the USB-A and audio port module from the chassis.
