Razer Blade Stealth 2016 RAM Replacement
  1. Razer Blade Stealth 2016 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six screws securing the battery.
    Phillips* screw heads not T4 Torx based on the photo.
    Sean Christiansen - crwdns2934203:0crwdne2934203:0
    You’re right! Thanks for the catch—I’ll fix that step.
    Arthur Shi -
  3. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heat sink.
  6. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the pins on the motherboard to remove the RAM.
    • WARNING: Be careful while using the soldering iron.
SadieGomez
crwdns2935283:009/21/21crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2021crwdne2935289:0
CMCSC-EGGLESTON-F21S3G19
Does anyone know what RAM modules I could use to replace the 8gb my 2016 stealth has? It still runs flawlessly but I'd like to have at least 16gb if possible.
Mike D - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,308
