Razer Blade Stealth 2016 Motherboard Replacement
  1. Razer Blade Stealth 2016 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six screws securing the battery.
    Phillips* screw heads not T4 Torx based on the photo.
    Sean Christiansen - crwdns2934203:0crwdne2934203:0
    You’re right! Thanks for the catch—I’ll fix that step.
    Arthur Shi -
  3. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
SadieGomez
crwdns2935283:009/21/21crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team 3-19, Eggleston Fall 2021crwdne2935289:0
CMCSC-EGGLESTON-F21S3G19
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Matias Urani - crwdns2934203:0crwdne2934203:0
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
Sarah Westberg -
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 883
