The motherboard is one of the most important components of the Razer Blade Stealth 2016 (Part # RZ09-01682E20). The motherboard has connectors in which the other circuit boards will be slotted. Essentially, all components lead back to the motherboard. If the motherboard fails, then so can almost every other component in your Razer Blade Stealth 2016. This guide will show you how to remove and replace the motherboard.
Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
Remove the rear cover by prying up lightly starting in one of the corners.
Use a Phillips screwdriver to remove the six screws securing the battery.
Phillips* screw heads not T4 Torx based on the photo.
You’re right! Thanks for the catch—I’ll fix that step.
Unplug the battery connector from the motherboard.
Remove the battery from the device.
Remove the red and black cables that are attached to the motherboard.
Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
Remove the heatsink.
Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
Remove the cooling fans.
Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
Hi Sadie. It's complicated for me with the battery disconnector, I can't remove it. would you help me with that?
Hi @matiasurani. It looks like the connector is covered by tape so you might have to remove the tape first. The battery is connected to the motherboard by a press connector. Take a look at this guide for how to disconnect it safely. Thanks!
