Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement
  1. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the black plastic lock-bar on the ZIF connector, then gently pull the ribbon cable directly out of its motherboard port.
  4. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw from the upper-right corner of the Wi-Fi card.
  5. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an ESD-safe tool under the black and gray coaxial cable connections, and gently lift the plugs vertically to disconnect them from the Wi-Fi card.
    • Grip the Wi-Fi card from both sides and pull it directly out of its port.
Jonah CW Charles
crwdns2935283:002/10/22crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 2-18, Eggleston Spring 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 2-18, Eggleston Spring 2022crwdne2935289:0
CMCSC-EGGLESTON-S22S2G18
crwdns2942667:0crwdne2942667:0 493
