Razer Blackwidow Chroma Key Switch Replacement
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Front Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
Annika Grace Ford
crwdns2935283:002/18/21crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G21, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G21, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S2G21
hello where to buy the switches for this keyboard?
ninja636 - crwdns2934203:0crwdne2934203:0
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 246
crwdns2942667:0crwdne2942667:0 25,125
