Razer Blackwidow Chroma Key Switch Replacement
  1. Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Rubber Feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Chroma Key Switch Replacement, Front Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Front Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
    Mine also had two clips on the left and right sides. Needed to run an opening tool over one side before I could open it
    Justin - crwdns2934203:0crwdne2934203:0
    In order to remove the keys at all you need to remove the led's as well, which have 4 pins and are awful to get out.. I would appreciate it if this guide had noted that before I started this repair..
    David Cropp - crwdns2934203:0crwdne2934203:0
  3. Razer Blackwidow Chroma Key Switch Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blackwidow Chroma Key Switch Replacement, Key Switch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-solder the anchor of each key that you desire to replace with a soldering iron.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the key switch once the de-soldering is complete.
    need to de-solder 4 led attachments as the led passes through the switch ... can not remove the key otherwise.
    D K - crwdns2934203:0crwdne2934203:0
Annika Grace Ford
crwdns2935283:002/18/21crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G21, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G21, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S2G21
hello where to buy the switches for this keyboard?
ninja636 - crwdns2934203:0crwdne2934203:0
I've seen Razer Green Switches (the ones for the Blackwidow) with RGB lighting available for sale on eBay.
I hope that helps!
Matt Von Grimm -
Hi Annika, I have razer black widow chroma overwatch edition, Is gateron optical switch compatible with it?
Jaydeep Parmar - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 252
crwdns2942667:0crwdne2942667:0 25,194
