Razer BlackWidow V4 Keycap Replacement
  1. Razer BlackWidow V4 Keycap Replacement, Keycap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With key cap tweezers, align and grasp the edges of the keycap with force.
    • Once you have a firm grasp, push in and up.
  2. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the keycap is off the keyboard from the center holder, simply pull up and place to the side.
    • Make sure to remember the orientation in which the keyboard was facing.
  3. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to realign the clip on the keyboard by simply pushing down on the side or center of the clip.
    • Make sure the clip is tucked in the center and both ends of the clip are parallel to each other making sure there is a keyboard wall inside the clip.
  4. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use either a dust cleaner or Co2 compressor to spray away any debris that may be inside the holder.
    • Make sure the clip does not fly away.
  5. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a caliper, measure the diameter of the fitment on the keyboard.
    • The measurements can either be of the side wall or center clip.
    • You can also use a ruler for this step.
  6. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure the diameter of fitment on the keycap.
    • They should be the same or off by .02+/- .
    • If the fitment is bigger or smaller than .02+/- do not try and force it in. This will cause keyboard issues.
  7. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Add a drop of keyboard cap lubricant to make sure that any friction or shear pressure is dispersed evenly throughout the lifespan of the keycap.
  8. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the orientation of which the keycap has to enter by noticing the clip holder on the keycap and the keyboard.
    • If the keyboard cap is OEM from Razer you do not need to worry about this step. The keycap contains a safety spacer that will not allow you to place it out of orientation.
  9. Razer BlackWidow V4 Keycap Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a slight force press down and hold.
    • Once the keyboard has been clicked in successfully, enjoy your keyboard.
Hemi_perez2000
crwdns2935283:002/21/24crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
CSU Sacramento, Team 1-4, Laflen Spring 2024 crwdns2935289:0CSU Sacramento, Team 1-4, Laflen Spring 2024crwdne2935289:0
CSUSAC-LAFLEN-S24S1G4
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 717
