Razer BlackWidow V3 Tenkeyless LED Replacement
  1. Razer BlackWidow V3 Tenkeyless LED Replacement, LED: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you start, unplug the keyboard from your computer to prevent accidental damage.
    • Use a keycap puller to all keycaps.
  2. Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the 7.85 mm screws that secure the case with a Phillips #0 screwdriver.
    • Avoid applying excessive force.
  3. Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully separate the backplate from the main keyboard body.
    • A plastic opening tool can be helpful to gently pry the pieces apart if needed.
    • Be patient and work slowly to avoid breaking any clips or the usb-connector.
  4. Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull out the cable holding the usb connector using your hand.
    • Ensure the cable is pulled straight back to prevent the usb-connector snapping.
  5. Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer BlackWidow V3 Tenkeyless LED Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to heat the four solder points securing the LED to the board, then apply a solder wick to absorb and remove the melted solder.
    • The soldering process involves high heat—handle the soldering iron carefully to avoid burns or damage to the circuit board.
Zach Nelson
crwdns2935283:002/18/25crwdne2935283:0
499 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 2-2, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 2-2, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S2G2
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 209
