Razer Basilisk V3 Switch Replacement
crwdns2942287:0crwdne2942287:0This guide outlines the steps for replacing the main left and right-click buttons on the Razer Basilisk V3 gaming mouse. Whether the buttons have become unresponsive or physically damaged, this guide will assist with installing new button modules to restore functionality.
crwdns2944105:0crwdne2944105:0
Heat the skate using a heat gun or hair dryer.
Using the pointy end of the spudger pry away a corner of the skate.
Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
Repeat these steps for each of the skates.
Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
Heat the label gently with a heat gun or hair dryer.
Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
Remove the two 4.8 mm screws using a JIS #1 screwdriver.
Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
Use the flat end of the spudger to pop-out the scroll wheel assembly.
Pull up on the top half of the cable connector and pull the cable from the connector.
Use the flat end of the spudger to press the two main button modules out from their mountings.
