Razer Barracuda X Volume Control Knob Replacement
Roman Walker
crwdns2944109:0crwdnd2944109:0Roman Walkercrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Sun 7, 2025crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This page is for the Razer Barracuda X. The guide is for the Volume Control Knob.
Make sure the device is fully off, and the device is not being charged.
  1. Razer Barracuda X Volume Control Knob Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Volume Control Knob Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Volume Control Knob Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
    What's battery used in this headphones?
    govno - crwdns2934203:0crwdne2934203:0
  5. Razer Barracuda X Volume Control Knob Replacement, Ear Pad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old cushion by pulling it off from the edge and out from the grooves.
  6. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  7. Razer Barracuda X Volume Control Knob Replacement, Microphone: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the microphone from the headset.
  8. Razer Barracuda X Volume Control Knob Replacement, Volume Control Knob: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 6 mm Phillips #1 screws that secure the cover.
    • Lift off the cover.
  9. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 6 mm Phillips screws that secures the volume control knob.
  10. Razer Barracuda X Volume Control Knob Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the volume control knob.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Roman Walker
crwdns2935283:009/23/24crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 3-1, Coppersmith Fall 2024 crwdns2935289:0University of North Texas, Team 3-1, Coppersmith Fall 2024crwdne2935289:0
UNT-COPPERSMITH-F24S3G1
Right ear stops playing when I set volume to max, and crusting noises when I change the volume. I suppose it's because of dirty potentiometer, just going through these steps and cleaning it with alcohol should work right?
Kisoma - crwdns2934203:0crwdne2934203:0
I've the exactly the same issue with you, I just removed the knob and sprey with first high pressure air then isopropyl alcohol, it's not completely fixed crusting noises they are still here but much more less that before also mine cuts the sound from the right side it's also fixed and for more better than before, I don't know how much holds but right now I'm happy :) Thanks for writer also.
Ali Demirkaya -
Could you tell me where I can get a potentiometer for these headphones? 102b that they don’t fit on aliexpress because the sound from the parav is lost
Сергій Хлевнюк - crwdns2934203:0crwdne2934203:0
could you tell me the measurements for the knob? Mine broke from being o tightened too much and use, so I wanted to 3d print a replacement
oviel rosario - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 818
