When your handle starts to have malfunctions fix them soon as possible for the best performance of the device. This device guide will go over a couple of problems we found with the handle. For instance, if you’re noticing that your handle is moving while you’re performing a task, this guide will help you fix that.
Lay the handle on it's side, with the screws facing up.
Remove the five 14mm screws from the rotating handle using the Phillips #1 screwdriver.
Unscrew the two 14mm screws from the clear bracket using the Phillips #1 screwdriver.
Remove the bracket.
Push handle rotation latch and seperate the rest of the handle from main body.
