The side brushes are a problem many people encounter when dealing with the RYDIS H68 Pro. This guide will show you how to fix a side brush issue.
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Lift the battery cover up to reveal the battery.
Remove the battery.
Remove the eight 10 mm Phillips #1 screws.
Hold the front bumper and pull it off.
Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
Unlatch the latches indicated. It can be easily done with your finger.
Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
This step just shows you how everything looks after the previous steps were completed.
Unscrew the five 10mm screws using a Phillips #1 screwdriver.
The side brush motor can now be removed by lifting it up.
