RX 480 Disassembly, cleaning and thermal paste replacement
  1. RX 480 Disassembly, cleaning and thermal paste replacement, Large view of the RX480: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This graphic card is really dirty, so this tutorial will show you how you can clean it and change the thermal paste
    • WARM UP THE CARD BEFORE THE TEARDOWN. IF THE CARD IS COLD THE THERMAL PADS MAY BREAK AND YOU WILL HAVE TO REPLACE THEM
    • Simply launch a game for a while or run a graphics benchmark to heat up the card.
  2. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Standard philips screw
    • Once the screws are removed, simply pull the fan up, they have no cables.
  3. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the backplate / front plate screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the backplate / front plate screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Standard Philips screw, be careful as they are not the same length.
  4. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the plastic panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be very gentle, you don't want to break the fan power system. You can use your nails if you're not getting it out with a tool, some twist left/right make the job DO NOT PULL FROM THE CABLE ITSELF!
  5. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • I personally clean the radiator using my vacuum cleaner, but you can just use a brush if you want.
  6. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the radiator: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the radiator: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Standard philips screw.
    • The radiator can feel "glued" to the card, don't hesitate to use a bit of muscle to separate them.
  7. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put some 70-90% alcohol, wait a bit for the thermal paste to get wet, then clean with a piece of makeup cotton, repeat until you get a proper result like in the third pic.
  8. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the GPU: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean with a Q-tip filled with alcohol
    • Put some alcohol on the gray chip, wait for the paste to get wet and clean with cotton.
    • Don't worry, alcohol is non conductible and will not damage your card.
  9. RX 480 Disassembly, cleaning and thermal paste replacement, Apply fresh thermal paste: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not hesitate to apply a bit more than me.
  10. RX 480 Disassembly, cleaning and thermal paste replacement, All the components before remounting: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're done! Time to reassemble.
crwdns2935229:05crwdne2935229:0
Zeiko
crwdns2935283:001/01/20crwdne2935283:0
298 crwdns2915208:0crwdne2915208:0
Would have loved to see a reassebmly after. But still exelent guide! 👏👏
koki michev - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 6,820
