ROG Strix G15 G512LI Disassembly
  1. ROG Strix G15 G512LI Disassembly, Removing The Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
    I have a problem taking the bottom cover off, based on the diagram shown the top right of the cover will not come off, i tried lifting it up but it seems like its gonna break.
    Galaxy NoahPlayz - crwdns2934203:0crwdne2934203:0
    Turned out that the screw wouldn’t let that corner out, however it ended up costing the cover to be broken, i kept unscrewing it and nothing, i think something was wrong with the structure of the screw itself, i cant get it out though.
    Galaxy NoahPlayz -
  2. ROG Strix G15 G512LI Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
    How do you remove the panel!? It looks like it will break. (Honestly have no idea why there are clips securing the bottom on this. They have ELEVEN screws in it! It ain't gonna move, not even for a 200lb gorilla like me lol
    Nicholas Royer - crwdns2934203:0crwdne2934203:0
    Nevermind. Got it open, but was scared of breaking something.
    The side vents (intakes or exhaust, not sure) have two clips each, so you need the little blue triangles to wedge in there and pop them loose.
    Nicholas Royer -
crwdns2935229:010crwdne2935229:0
June
crwdns2935283:009/28/21crwdne2935283:0
590 crwdns2915208:0crwdne2915208:0
how to fix the light bar i have one side wont light on
fethallah - crwdns2934203:0crwdne2934203:0
If I break the rgb light strip connector which, what are specs of that cable.? What should I order from online?
Ashvith - crwdns2934203:0crwdne2934203:0
not worth the money to replace but if you really need to then you might have to get from Ali Express
Cello Digital Phones - crwdns2934203:0crwdne2934203:0
@fethallah ROG STRIX light bar is known to breaking down easily and stop working. i personally just removed the connector and let it be without the lights.
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 178
crwdns2942667:0crwdne2942667:0 10,129
