RK61 Battery Replacement
  1. RK61 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RK61 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the Type-C cable from the top left of the keyboard.
  2. RK61 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the keyboard over so the bottom case is up.
    • Use a Philips #00 screwdriver to unscrew all four M2 5mm screws located on the back of the keyboard.
  3. RK61 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the keyboard case from the PCB (Printed Circuit Board).
  4. RK61 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the old 1450 mAh lithium-ion battery by gently pinching and pulling from the right and left sides of the connector.
    • Make sure to be extremely gentle when unplugging the old lithium-ion battery from the keyboard.
  5. RK61 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug in the new 1450 mAh lithium-ion battery by the connector.
  6. RK61 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the newly inserted 1450 mAh lithium-ion battery parallel to the edge of the PCB (Printed Circuit Board) and cover the PCB with the keyboard case.
  7. RK61 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Philips #00 screwdriver to screw back the four M2 5mm screws on the back of the keyboard.
  8. RK61 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RK61 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug in the Type-C cable on the top left of the keyboard.
    may I ask where did you buy your replacement battery, and if possible please reply it to my email hannahgayletabali@gmail.com my current battery is very inflated and I do not know where to buy a replacement
    Hannah Gayle Tabali - crwdns2934203:0crwdne2934203:0
    Is it possible to use the keyboard without a battery? I prefer to use it plugged in all the time
    Shafira - crwdns2934203:0crwdne2934203:0
Michelle Chen
crwdns2935283:005/10/21crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
York University, Team S1-G4, O'Regan Summer 2021 crwdns2935289:0York University, Team S1-G4, O'Regan Summer 2021crwdne2935289:0
YORK-O'REGAN-SU21S1G4
crwdns2947412:010crwdne2947412:0
Is it possible to replace the standard battery with a larger one with no issues other then additional weight? say a 4000 mAh which will just be longer?
shon malka - crwdns2934203:0crwdne2934203:0
There should be no issues with replacing the keyboard with a larger battery as long as the connector is the same size and the battery is small enough so that you can still cover the PCB entirely with the keyboard case.
Michelle Chen -
hey did u ever wind up doing the mod?
albert einstein -
yo. ty for the guide.
i am also interested in upgrading the battery but am unsure about:
which dimensions the new battery should be, or how to find out
if it is safe to further modify the kb with additional material through the usual mods ppl to
albert einstein - crwdns2934203:0crwdne2934203:0
should be fine to mod it to your liking
to measure simply measure the length breadth and max height u can have inside the cover and get a battery accordingly
Ispeakforus -
My battery is glued on the case. Any tips to remove it?
Adrian - crwdns2934203:0crwdne2934203:0
Will the keyboard work, if I remove the battery and use the Keyboard wired?
Albert Zweistein - crwdns2934203:0crwdne2934203:0
Yes, it'll work. Occasionally, the spacebar led will flash for a second or two but other than that, it works just fine.
Vance Tan -
Where can I find a replacment battery for the RK61?
Joshua Good - crwdns2934203:0crwdne2934203:0
Hi, where did you purchase the replacement battery? I'm looking online for one and am only finding Aliexpress selling similar ones.
lakjhdf - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 199
crwdns2942667:0crwdne2942667:0 17,416
