RIDGID R84015 X2 Disassembly
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R84015 X2 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure plastic is not broken and switch is not stuck.
Brian
crwdns2935283:004/12/10crwdne2935283:0
100 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-48, Garner Spring 2010 crwdns2935289:0Cal Poly, Team 15-48, Garner Spring 2010crwdne2935289:0
CPSU-GARNER-S10S15G48
crwdns2931471:06crwdne2931471:0
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 13,967
