Prerequisite only
Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
Maneuver the saw to get to the base plate.
Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
