RIDGID R32104 Motor Bearings Replacement
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Motor Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Gear Box: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
Lucas Pimentel
crwdns2935283:004/02/19crwdne2935283:0
1,010 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G1, Julie Spring 2019 crwdns2935289:0UMass Dartmouth, Team S5-G1, Julie Spring 2019crwdne2935289:0
UMASSD-JULIE-S19S5G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 732
