RICATECH-RTT22 Turntable Belt Replacement
  1. RICATECH-RTT22 Turntable Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the arm holder by moving the needle to the side and lifting up.
    • Remove the rubber pad by lifting it up.
  2. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the record player. There should be screws (10mm phillips head) on the back.
    • Use your phillips head screwdriver to remove each screw (keep them in a safe place for later).
  3. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be three wires connecting the top to the bottom. Disconnect them carefully.
    • Put the back component of the record player to the side.
  4. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your phillips head screwdriver to remove the three screws (8mm phillips head) holding the motor in place.
    • Keep in mind that there is some pressure on the motor, since the belt holds together the motor and turntable.
  5. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unbolt (6mm bolt) the turntable from the housing using your wrench.
    • Since the turntable is designed to rotate, make sure the other side of the pin is kept from rotating while unbolting.
  6. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully removed the rubber band from around the motor and extract the turntable from the device.
  7. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the damaged belt. Place the new belt around the turntable.
  8. RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RICATECH-RTT22 Turntable Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow the instructions backwards to reassemble the record player.
Celeste Greenbaum
crwdns2935283:003/08/17crwdne2935283:0
Delft University of Technology, Team S1-G14, Flipsen Spring 2017 crwdns2935289:0Delft University of Technology, Team S1-G14, Flipsen Spring 2017crwdne2935289:0
TUD-FLIPSEN-S17S1G14
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 846
