Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
Apply a little dot on the pad and place on the heatsink.
After speading it with a spatula, stick two together, and slide to distribute evenly.
Careful as to not damage the pads!
Apply a thin layer using the spatula on the transistors as well.
Mount the amplifier board back on its place.
Carefully set the transistors using the screws.
Fix the power board using its screws.
Check that there are no shorts between the transistors and the heatsink or backplate.
