Is your iBUYPOWER RDY Y70 001 suffering from faulty RAM? Then look no further. This guide will teach you how to replace faulty RAM, or to add current RAM for the to your iBUYPOWER RDY Y70 001. Make sure to turn your PC'S power off before starting!
Make sure the PC is not powered by unplugging it
Take the screws off using an Allen key
Pull the window off the PC
Remove current RAM
Push down on the clips holding down the current RAM
Install new RAM
Carefully apply pressure downwards on the RAM stick until the clip locks itself.
Put the window back onto the PC case
Screw the window onto the PC case
Hopefully your RDY Y70 001 is running smoother and faster than it was before.
