RCA Voyager II RCT6773W22 Disassembly
  1. RCA Voyager II RCT6773W22 Disassembly, RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Have Workstation Prepped
  2. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the two screws on the top of the device with a PH000 screwdriver
  3. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting from the top, place pick or plastic tool between the power button and screen edge and push apart slightly.
  4. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run pick across the top to the right and then down the right side and around the rest of the tablet.
    • There is a good amount of space between the bezel and the board. Be gentle, but the risk of breaking components is low.
  5. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • lift section out of the black casing from the bottom, lift and remove by pulling away from tablet.
  6. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Battery connection (on older models, may be soldered to board)
    • Front Camera
    • Digitizer
    • LCD
    • Speaker
    Where can I buy the LCD piece separately?
    Rica
    MO
    Lamarica Crawford - crwdns2934203:0crwdne2934203:0
  7. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery Connection First
    • Do not use any metal tools while the battery is plugged in. It may cause a short.
    What the name to this part that cover the flex cable I lost the clamp.
    Kiyona Nichole Woods - crwdns2934203:0crwdne2934203:0
  8. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • unplug the speaker
  9. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black cover over all three flex cables (Camera, LCD, Digitizer) with a plastic tool.
    • The covers are incredibly fragile, and easy to break
    • gently disconnect all three cables with your fingers by pulling slightly
    Can I get these cable covers because I lost one
    HL Devices - crwdns2934203:0crwdne2934203:0
  10. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • remove the three screws securing the board with your PH000 Screwdriver
  11. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • lift the board out gently
    • Do not tug the board out too hard, the antenna cable on the left is soldered in!
    • Fold board over the left side of the tablet and gently remove tape securing antenna to the case. Use a small amount of heat if necessary.
  12. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • remove tape from top and bottom of the battery.
    • with a plastic piece, lift battery from adhesive securing it in place.
    • do not use a metal or sharp tool to remove the battery, tearing or puncturing it may cause it to explode or heat rapidly, and may damage your device.
    • The battery is secured directly to the back of the LCD. Exercise caution while removing the battery not to damage the LCD.
    • The battery is soft and somewhat malleable - it can bend slightly without damage.
  13. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place picks between the lcd and the plastic clips holding it in place.
    • The pick placement to the top left side (near the power button) is smaller and on a corner. I recommend inserting this pick last.
  14. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently push top right pick down to lift LCD from the clip. Run across the top and right side to further lift LCD.
    • Use picks as needed to separate LCD in other areas.
  15. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once separated and loose, remove picks so you do not damage the LCD while removing it.
    • To remove, lift top of LCD and pull out of case away from the speaker, which is fixed to the digitizer frame.
  16. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • to remove Digitizer/Glass from the frame and speaker, slide a pick under a corner between the glass and frame to loosen adhesive
    • If you're having issues loosening the adhesive, use a heat gun around the edges, then try again.
  17. RCA Voyager II RCT6773W22 Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have completely dismantled the RCA Voyager II
crwdns2935229:035crwdne2935229:0
Chris
crwdns2935283:001/11/16crwdne2935283:0
2.025 crwdns2915208:0crwdne2915208:0
crwdns2947412:031crwdne2947412:0
what is that flat part that has the little copper bar in the middle. What do you call that?
TheUnchanted Sword - crwdns2934203:0crwdne2934203:0
The LCD has a piece of copper tape on it, is that what you mean?
Sam Goldheart -
Nice Guide. Very Simple and Easy to follow!
Aerial L - crwdns2934203:0crwdne2934203:0
Bonne site merci pour tous je suis très heureux content que entrer dans ce site
diego jamal - crwdns2934203:0crwdne2934203:0
Anyone know which company made this very fragile digitizer for RCA Voyager?
Spock Chen - crwdns2934203:0crwdne2934203:0
This is a tricky question, but I think it is RCA…
Om rabi -
where can I get the battery for my RCT 6773W22B? and what is the difference from ur model?
Appreciate ur work and helping the less inclined
Byron B
Ccl Byron - crwdns2934203:0crwdne2934203:0
Both my tablet stop working.It doesn't want to charge.And when I open it i saw something white on the grey wire near the Digitizer.
Mary - crwdns2934203:0crwdne2934203:0
Where can I find a screen for my voyager it has a crack inside
Karmyn Miller - crwdns2934203:0crwdne2934203:0
https://www.amazon.com/Atabletparts-Repl...
$9.99 Replacement Digitizer Touch Screen for RCA 7 Voyager II RCT6773W22B
candy_schworak -
Thank you, Thank you for this guide. This was the best step by step guide! I saw a few clips on YouTube but your guide was the best & easy to follow. It took me about an hour & 15 min to replace the screen on my granddaughter's tablet.
The biggest bear was separating the front & back. After that, it was pretty easy going. Your close-ups of the ribbons & connectors were great. THANK YOU AGAIN - I really appreciate it that you wrote this guide ! !
candy_schworak - crwdns2934203:0crwdne2934203:0
I appreciate your kind words. When I discovered no step by step for my own daughter's tablet I decided to make one myself. I'm glad I was able to help!
Chris -
awesome…. however my antenna became unsoldered…. any tips for reapplying?= thanks greatly
Mark Forsyth - crwdns2934203:0crwdne2934203:0
So heat is not required to remove the digitizer completely?
Dudefoxlive - crwdns2934203:0crwdne2934203:0
Update. Heat is not required but might make removing the screen a little easier. I did remove the old screen form my friends tablet with no heat and a little 99% IPA removed the little bit of adhesive that was left behind. The new screen went on perfectly and the tablet works PERFECTLY. Another Successful repair thanks to Ifixit and there repair guides and tear-down guides. I knew what i was in for when i started.
Dudefoxlive -
What does the grey wire need to be attached to? The one end of the wire has come loose and is attached with black tape, the other is attached to the circuit board? What am I to do to repair the wire? Surely it belongs somewhere.
Rebecca Roberts - crwdns2934203:0crwdne2934203:0
The little black piece of tape it was soldered too is actually the antenna.
David Cross - crwdns2934203:0crwdne2934203:0
Somehow small ants got under the screen on my sons tablet is there anyway to get them out without taking it all apart? Thank you!!
Tabatha Arbuckle - crwdns2934203:0crwdne2934203:0
That is odd! Try maybe some canned air in the ports see if you can blow them off the screen. Realistically, you can’t get them out without removing it.
Chris -
This is a phenomenal post!! One of my RCA voyager II 16 gb tablets needs a battery badly..thanks to this post I dont have to toss the tablet!
Joe Salles - crwdns2934203:0crwdne2934203:0
Thank you, I really appreciate that.
Chris -
My screen is crack in the inside do I need a LCD for it
Youlanda Smith - crwdns2934203:0crwdne2934203:0
Most likely.
Chris -
Why will my unit just keep flashing the battery charging sign at intervals and not boot up to a full screen?
mainmicros - crwdns2934203:0crwdne2934203:0
Is it possible to just remove the old battery and plug in a new one at the battery step? And is my battery no longer chargeable when it shows fully charged but only works for 15 min if that long? Thank you so much for your detailed video - it gives me hope that I can still revive my tablet.
Tove - crwdns2934203:0crwdne2934203:0
my tablet has not been turning on and i have charged it and everything
Taylor Johnson23 - crwdns2934203:0crwdne2934203:0
This is an amazing guide. Thank you so much. My daughter keeps breaking her screens. She will be so happy her tablet could be fixed, and for free too!!
nancyjo680 - crwdns2934203:0crwdne2934203:0
Why does my tablet keep restarting and is there anything I can do to fix the problem? Sometimes it will run for a while and restart at random different times, and other times it won't even get to the lockscreen and will just keep restarting over and over. I already tried a factory reset I don't know what else to do any kind of feedback would be greatly appreciated. Thank You
Jeremy Warner - crwdns2934203:0crwdne2934203:0
Where can i get the Lcd for the exact model ( rct6773w22… LCD only
Ac tavious - crwdns2934203:0crwdne2934203:0
I live in the USA, state (Missouri). Where can I get a battery for my RCA Voyager 2 tablet?
Percy Woodson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 21,950
