RCA RP3715A Display Replacement
  1. RCA RP3715A Display Replacement, Reaching the battery terminal.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RP3715A Display Replacement, Reaching the battery terminal.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Display Replacement, Replacing the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Display Replacement, Getting inside the device.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Display Replacement, Relieve extension cord tension.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement, Relieve extension cord tension.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement, Relieve extension cord tension.: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RP3715A Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RP3715A Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Display Replacement, Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  9. RCA RP3715A Display Replacement, Detaching the front panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10 mm Phillip's #1 screws.
  10. RCA RP3715A Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gray panel from the frame.
  11. RCA RP3715A Display Replacement, Unlatch release tabs: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement, Unlatch release tabs: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RP3715A Display Replacement, Unlatch release tabs: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The two latches located in the picture will help take off the display.
    • Remove the display.
Myles Waiters
crwdns2935283:009/22/14crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-5, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-5, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G5
crwdns2942667:0crwdne2942667:0 443
