This guide will illustrate how to replace the battery.
Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
Place the plastic opening tool between the case and the screen.
Slide the tool clockwise around the case until all the clips are removed.
Desolder the two wires that connect the battery to the motherboard.
Using the blue plastic opening tool, lift the battery away from the device.
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
