RCA RCT6303W87 Battery Replacement
  1. RCA RCT6303W87 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
    I bought a set of tools for opening the cover of the tablet but as much as I have tried going around each side, I have been unable to make any progress. I can’t get a tool to even begin to fit in between the cover and the tablet. Any suggestions?
    Thomas Kiker - crwdns2934203:0crwdne2934203:0
    I was getting very frustrated as I tried to separate it. I thought maybe there was glue around it's because my son had just replaced the screen. I have the RCA 11 and 1/2 Galileo Pro it has snaps all the way around it. Once I realized that it started to snap apart. I became a little bit more confident. You have to get the snaps to start unsnapping.
    Rebecca Pavelka - crwdns2934203:0crwdne2934203:0
  3. RCA RCT6303W87 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove cover completely.
  4. RCA RCT6303W87 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6303W87 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel off the battery.
crwdns2935229:016crwdne2935229:0
Akitaka Hashimoto
crwdns2935283:003/27/18crwdne2935283:0
540 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G2, Harley Spring 2018 crwdns2935289:0IUPUI, Team S3-G2, Harley Spring 2018crwdne2935289:0
IUPUI-HARLEY-S18S3G2
crwdns2947412:05crwdne2947412:0
Thank you very much for the instructions. I was totally in the blind about what to unplug or not.
Diamante Swift - crwdns2934203:0crwdne2934203:0
“Remove nine 4.8mm screws “ but you only show pictures of 7 screws.
George Phillips - crwdns2934203:0crwdne2934203:0
2 are hidden under the black hinge. you would have to remove the 3 tiny screw in order to get access to the hidden 2 screws.
Ed Barry -
Thanks for the instructions. I don’t know if mine is newer or older but the bus cable turns 90 degrees and goes under the keyboard cable so step 6 really wasn’t necessary. A plastic putty knife slid under old battery loosening the adhesive so you can slide it out from under the bus cable.
Steve Bunce - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,411
