In this guide, you will learn how to replace the speaker on your device.
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Press the plastic opening tool into the space between the front and back portions of the case.
Run it along the perimeter of the device to unhook the plastic tabs.
Gently pull both sides apart.
Remove the soldered wire connections to the speaker.
Pry the speaker gently out of its plastic enclosure using a spudger.
