RCA RCT6272W23 Motherboard Replacement
  1. RCA RCT6272W23 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6272W23 Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6272W23 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA RCT6272W23 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA RCT6272W23 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
    Unsoldering the motherboard is not necessary to replace the display. Once cables are disconnected from the mother board, the motherboard and the battery should remove as one complete piece.
    nerdatheart - crwdns2934203:0crwdne2934203:0
  4. RCA RCT6272W23 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6272W23 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the motherboard from the rest of the body.
Stephen Radachy
crwdns2935283:003/17/15crwdne2935283:0
819 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-5, Lauer Spring 2015 crwdns2935289:0Michigan Tech, Team 1-5, Lauer Spring 2015crwdne2935289:0
MTU-LAUER-S15S1G5
i need to know everything there is about the motherboard. an tablet. images, info etc
Paul Shreves - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,141
