RCA RCT6272W23 Battery Replacement
  1. RCA RCT6272W23 Battery Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6272W23 Battery Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6272W23 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
Stephen Radachy
crwdns2935283:003/17/15crwdne2935283:0
819 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-5, Lauer Spring 2015 crwdns2935289:0Michigan Tech, Team 1-5, Lauer Spring 2015crwdne2935289:0
MTU-LAUER-S15S1G5
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 5,663
