RCA RCT6077W2 Camera Replacement
  1. RCA RCT6077W2 Camera Replacement, Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6077W2 Camera Replacement, Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
  2. RCA RCT6077W2 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA RCT6077W2 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
  3. RCA RCT6077W2 Camera Replacement, Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
    • Do not use force to try to remove the ribbon cable. The latch may not be lifted up completely, and force can break the ribbon cable away from its connector.
  4. RCA RCT6077W2 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
Ryan Williams
crwdns2935283:001/27/15crwdne2935283:0
1,157 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 1-2, Prince Winter 2015 crwdns2935289:0Pasco Hernando, Team 1-2, Prince Winter 2015crwdne2935289:0
PHSC-PRINCE-W15S1G2
crwdns2931471:06crwdne2931471:0
Where can I get the replacement parts (camera and flex cable)
tuesday cannon - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,020
