This guide will show you how to take off and replace the screen of your Lyra.
Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
Remove the battery plate.
Place your finger at the bottom of the battery.
Lift up on the battery until it pops out from the LYRA X2400.
Remove the two Phillips screws from the silver cover at the top of the Lyra.
Slowly wiggle the silver cover while pulling it away from the device.
Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
Pull the silver case from the bottom of the device.
Carefully pry up the screen with a plastic opening tool.
Disconnect the screen's ribbon cable from the circuit board.
Remove the screen.
