RCA Lyra X2400 DC Power Adaptor Replacement
  1. RCA Lyra X2400 DC Power Adaptor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 DC Power Adaptor Replacement, Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement, Screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 DC Power Adaptor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 DC Power Adaptor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 DC Power Adaptor Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 DC Power Adaptor Replacement, DC Power Adaptor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA Lyra X2400 DC Power Adaptor Replacement, DC Power Adaptor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the DC power adaptor component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the DC power adaptor.
    • If you need information on soldering, check out this guide.
    • Once removed replace it with the new working DC power adaptor.
    • Use the soldering tools to reattach the component back to the main logic board.
Joseph Goodwin
crwdns2935283:004/11/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-3, Regan Spring 2013 crwdns2935289:0Cal Poly, Team 17-3, Regan Spring 2013crwdne2935289:0
CPSU-REGAN-S13S17G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 279
