RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
Marcus Elysee
crwdns2935283:010/25/19crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G8, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G8
Where can I buy this motherboard?
waymond everett - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,469
