Remove the three Phillips #00 screws at the bottom of the device.
Remove the two Phillips #00 screws to the left and right of the keyboard connector.
Pull on one of the bottom corners to begin to pull off the back plate.
Work around the outside of the chassis, using the spudger to pry the backplate off.
Identify the grey wire on the right side of the device.
Remove the orange ribbon cable over the wire.
Remove the antenna using a soldering iron.
Does anyone know where I can buy a new antenna for this device?
