This guide will teach someone how to replace a watch strap of the Quiksilver The Fifty50 sports watch. Watch strap damage could be from sports activity. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are replacing the watch strap, that way there will be no surprises as you go through the steps.
Place the watch (face down) on a solid surface.
Carefully use the screwdriver and push in one side of the strap.
Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
Gently pull the pin out of the strap.
what size band is replacement 22mm? 24?
