If your Quiksilver The Fifty50 sports watch has not been turning on or seems to be having battery issues this guide will successfully teach someone how to remove the analog battery. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are replacing the battery, that way there will be no surprises as you go through the steps.
Place the watch (face down) on a solid surface.
Carefully use the screwdriver and push in one side of the strap.
Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
Gently pull the pin out of the strap.
Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
Carefully separate the panel off of the watch.
Carefully lift the white plastic circular out of the watch.
Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
Remove the large circular Analog battery.
