Locate your device.
Flip device onto its back.
Locate the battery and remove it.
If you wish to replace the battery you can do so here.
Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
After removing the panel and the battery, your tablet should look like this.
Locate the tablet's antennas.
Remove the two 3x2.5mm screws holding them down.
Remove antennas and replace them as needed.
