Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
Use the iFixit plastic opening tool to pry open the back of the tablet.
In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
Use the spudger to remove the ribbon.
Use the spudger in the top corner of the tablet and lift the camera up.
Lift the tape over the wires that are holding them to the tablet insulation.
Pull out the motherboard and set it aside.
