Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
Use the iFixit plastic opening tool to pry open the back of the tablet.
Remove the tape connecting the battery to the motherboard.
Remove the black tape attaching the wires to the battery.
Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
