Puritan Bennett 840 Oxygen Sensor Replacement
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
  2. Puritan Bennett 840 Oxygen Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
  3. Puritan Bennett 840 Oxygen Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
  4. Puritan Bennett 840 Oxygen Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
  5. Puritan Bennett 840 Oxygen Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
Gabrielle Reyes
crwdns2935283:004/09/20crwdne2935283:0
154 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G4, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G4, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G4
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 2,451
