Puritan Bennett 560 Internal Battery Replacement
  1. Puritan Bennett 560 Internal Battery Replacement, Internal Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • REMOVAL
    • Locate the battery cover on the rear of the ventilator.
  2. Puritan Bennett 560 Internal Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T10 Torx screwdriver, remove the three 8mm screws on the battery cover.
    • Two screws are located on the rear of the ventilator, and one on the bottom.
    • Slide the battery cover out of the ventilator.
    • Remove the battery from the battery cover.
  3. Puritan Bennett 560 Internal Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • REPLACEMENT
    • Install the battery into cover, as shown in figure.
    • Make sure the contacts on the battery line up with those in the ventilator.
    • Slide the battery and cover together into the housing.
    • While applying pressure to the cover, install the two rear screws.
    • Install the screw at the bottom of the cover.
    • Be careful not to over-tighten any screws.
Theo Philliber
crwdns2935283:004/07/20crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G20, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S11-G20, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S11G20
I can’t seem to edit the step titles. They should show:
Step 1: Battery Removal
Step 2:
Step 3: Battery Replacement
Theo Philliber - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 610
