Pulsar Xlite V2 Wireless Battery Replacement
  1. Pulsar Xlite V2 Wireless Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pulsar Xlite V2 Wireless Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disassembly is the first step, which requires something thin like a mini pry bar or even your fingernails, to remove the lower mouse skate on the flat underside of the mouse.
  2. Pulsar Xlite V2 Wireless Battery Replacement, Unscrew the underside: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the mouse skate, use a Phillips screwdriver to unscrew two screws and detach the bottom layer of the mouse.
  3. Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pulsar Xlite V2 Wireless Battery Replacement, Separate the bottom layer: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To separate the bottom and top layer, begin lifting the bottom half of the mouse.
    • Next, apply some pressure by pushing the top layer towards the hinges seen in the second picture. Then, the entire top layer can be lifted off.
  4. Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pulsar Xlite V2 Wireless Battery Replacement, Disconnect the old battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is located towards the lower end of the mouse in a rectangular housing, where the palm would usually rest above, along with wires connecting to its white 3-pin slot towards the opposite side of the battery location.
    • Remove the connector from its slot and the battery.
    • The new battery can now be attached in the opposite manner by connecting the 3-pin connector in its slot.
    • The connector pin can initally be tightly secured meaning you might require slightly more force than you expect to detach the pin. Be wary of the surrounding parts near the pin as to not damage the rest of the mouse.
    • Reassembly is simply steps 2 through 4 in reverse order.
    • However, when finishing with step 2, the bottom mouse skate can be easily applied without the user of fingernails or the mini pry bar.
Now that you've successfully replaced the battery, enjoy the renewed efficiency and responsiveness of your Pulsar Xlite V2 Wireless mouse. Happy computing!
Darrin Du
crwdns2935283:010/24/23crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 12-3, Ribeiro Fall 2023 crwdns2935289:0CSU Los Angeles, Team 12-3, Ribeiro Fall 2023crwdne2935289:0
CSULA-RIBEIRO-F23S12G3
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 3,003
