crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Puffco Peakcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Puffco Peak Teardown, Remove base plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Puffco Peak Teardown, Remove base plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is held on with adhesive tape. You can warm this up with something to soften the glue
  2. Puffco Peak Teardown, Remove the rubber boot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the glass, roll the rubber boot from the bottom up, and slide off in one piece.
  3. Puffco Peak Teardown, Remove screws from case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • These are small T6 Torx screws that need to be removed to separate the case halves
  4. Puffco Peak Teardown, Separating case halves: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screws are removed, remove the warranty tape (notice the void after removal). The halves are held together with glue. I warmed mine up on a heating mantle.
  5. Puffco Peak Teardown, Removal of board assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Puffco Peak Teardown, Removal of board assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the halves are separated, you can carefully remove the board. Take care not to break the two wires that connect to the case LEDs. Now you can access and repair or replace switches, lights and charge ports, extending the life of your $400 investment!
Marco Onoroto
crwdns2935283:012/14/19crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
Dude… thank you. Nothing but love from Madison, WI
DJ Hogan - crwdns2934203:0crwdne2934203:0
Dose anyone know how to fix one tht
Kevin Martinez - crwdns2934203:0crwdne2934203:0
So I got to this point today actually and the problem I had that it wasn't charging I believe you think I just replace that port and if so any idea what I should look up to figure out how to change said port?
Aiden - crwdns2934203:0crwdne2934203:0
Thanks for sharing the information on the puffco peak pro vape
Vaibhav Sharma - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 246
crwdns2942667:0crwdne2942667:0 13,433
